Old 06-20-2006, 07:10 AM   #1
gmj4sea
Your Ride: 1198 740i
Unhappy breaks/front end
i have 1998 740i and when i touch the break at high speeds the front end gets violent. so i changed the tie rod assembly and then got a front end alignment problem got little better i also checked for any play underneth and everything feels tight. wheel bearings do not have play. any help would be great.
Old 06-20-2006, 07:26 AM   #2
Rate My Car: 102 / 329
First thing I'd suspect is the rotors. Have them inspected for lateral runout, and corrected, if necessary. If they tell you it's 'warped', go to someone else, because they may not fix it using the correct procedure . . rotors don't actually warp; the term is a misnomer.
Old 06-20-2006, 09:51 AM   #3
EVLBLK7
Rate My Car: 64 / 329
Your Ride: 2001 740iL Sport
I would have to agree with Dudesky it definitely sounds like rotors, the only way you should fix that on these cars is to replace DO NOT RESURFACE them you will make the problem worse and the car will not stop as well.
Old 06-22-2006, 06:43 AM   #4
gmj4sea
Thanks guys i will have the rotors checked and post back.
Old 06-22-2006, 09:25 AM   #5
Rooz
Rooz's Avatar
Rate My Car: 7 / 329
Your Ride: 2003 M5
if you change rotors, might as well change pads while you'r at it
VIEW MOD LIST & PICS
Originally Posted by Gregg
Old 06-22-2006, 11:06 AM   #6
dinan540
dinan540's Avatar
Sounds like your rotors.
540i with some mods
Old 06-29-2006, 07:17 AM   #7
gmj4sea
Thumbs down replaced rotors and pads
i replaced the rotors and pads in the front got a little better but still there. any more ideas.
Old 06-29-2006, 07:29 AM   #8
Merely replacing the rotors often doesn't cure the wobble caused by lateral runout, because the defect is in the hub. Did they cut the new rotors to match the hub? here's more detailed info:
http://www.brakeinfo.com/html/lateral.html
http://mta.org.nz/?id=751&eid=427
If the runout was accounted for, then you might have worn suspension bushings. I don't know much about the 7 series, but on a 3 series, worn control arm bushings can manifest itself in front end shimmy when braking at high speeds.
Old 04-15-2007, 11:20 AM   #9
NewBIMMERfan85
NewBIMMERfan85's Avatar
Your Ride: 1988 735I
Same prob here
yeah i have an 88 735i that does that on the passenger side front but the rotor looks perfectly fine and the pads like new but itll happen very often it would wobble like hell the it would stop, but the brake system didnt have any fluid and at the time i got so the caliper what locken up when we got it and had to park so could the caliper be getting stuck a mid brake or what?
Old 04-15-2007, 11:53 AM   #10
Rate My Car: 173 / 329
dude, what?
if its the same problem, if you are going at a low speed, like 40mph and you hit the brakes hard what happens?
Old 04-15-2007, 12:19 PM   #11
NewBIMMERfan85
wobble like hell but it doesnt happen all the time just everyone in a while
Old 04-15-2007, 12:33 PM   #12
ahh, could it possibly be while you are turning, hence why there is only a problem on one side
Old 04-15-2007, 01:00 PM   #13
MTurboPower3
MTurboPower3's Avatar
Your Ride: Dont have a car yet
mayb theres nothing wrong with the car because it is a 98 740 which is probably the best 7 series every made it could be that he doesnt know how to brake smoothly
Old 04-15-2007, 05:21 PM   #14
NewBIMMERfan85
no im talken about a 1988 735i and theres nothing really smooth about it
like itll brake smooth sometime then it start wobbling harsh and as u apply harder it stops
Bucking rear end? doughboyea E46 35 12-22-2006 11:00 AM
97 e39- groaning in front end jbeattie E12, E28, E34, E39, E60 16 04-14-2006 12:30 PM
End of the World - 31 Years komodo United Off Topic  **FOR MEMBERS ONLY** 19 12-09-2005 12:47 AM
MS Paint the End of the World komodo United Off Topic  **FOR MEMBERS ONLY** 31 10-26-2005 01:28 AM
Rubber at the End komodo Comedy Collection
4 07-18-2005 01:59 PM
