Hi guys,
A friend sent me the link to this thread on my car... thanks for all your kind words!
Perhaps I can clear up a few details...
Originally Posted by Rooz
The tran is actually a 6-speed transmission from the limited production 850CSi V12 supercoupe
Started out that way... required significant modification to accept the later M73 engine's timing sensor integrated into the bellhousing and flywheel. We did the custom flywheel, based on the product we do for the E60 M5.
Originally Posted by cainchapman
You guys must feel ripped off if that's all your smogged up E39 M5's put out.
Ours are 400hp standard.
US M5s are the same. That dyno chart is wheel horsepower, not crank. A UK/Euro market M5 will show the same results.
Originally Posted by Chris
confused.... so it has twin supercharger AND 6.0 conversion? That doesn't make sense, it should be putting up way more than what those dyno charts showed.......
No supercharger, no 6.0l... those were proposed ideas that never materialized. Performance mods were limited to a change in characteristics of the engine management with the transmission electronics change, ExtrudeHoned intake manifolds, overbored throttle bodies, full race cat and free-flow exhaust, and diff swap.
The dynos on the website show some, but not all, of that. Car is much stronger now, time fore new dyno sheets!
anyone else catch the pictures of the drive shaft completely destroyed on the more pics link? *WOWOWOWOWOWOWOWOwOW*
Yeah, that was a surprise. Of course it happened on a dark road around a blind curve in the middle of the night. Fun times.
Originally Posted by TerryY
The story is a rather stale copycat if you followed the Saga of Bimmerhead and Baby on Bimmerforums.
Other way around. Project X was in the works first, and I consulted on Baby with the owner, Simeon, and the builder, VAC. It's a bit easier to do a 740 6-speed... all factory parts. Not so with the 750!
Yeah, but probably the Sponsors paid for most of it...
Heh. Considering I
am the sponsor, you're right!
Actually, the folks at Polk were awesome about the audio system, they did help out with that. Absolutely amazing quality and their "dreamworks" shop is absolutely incredible.
This is the E38 I've been dreaming about since 1999 when the 740i Sport was introduced... I knew that something with just a little bit more salt could be built.
- Rob Levinson
