Old 09-29-2010, 01:00 AM   #1
coleshooter
Your Ride: 2001 BMW 740il
Exclamation 2001 740iL (e38) Making Chugging Noise
My 2001 (produced Nov. 2000) 740iL with 86k miles has been making this chugging noise for a few weeks now. It happened a few days after changing the oil (using Mobil 1 Full Synthetic 5w30) and replacing the valve cover gaskets.
The evening it began, I had just replaced the fuel tank pressure valve, but it seems that's likely coincidental. I've heard that it could be the VANOS system. Edwin from Bimmerboard ran a can of Winn's Engine Cleaner (http://www.bimmerboard.com/forums/posts/642715) and it seemed to make a difference, but i'm not sure his sounded as bad as mine does, and mine was a very sudden onset. It does have the usual VANOS clatter when starting it.
Could there be a problem with the oil i'm using, or something we might have done while replacing the valve cover gaskets? (they were a pain to get off and back on, but they're not seeping and we didn't hit anything.) I'm not quite sure what to do, would prefer to avoid Alderson BMW (The $tealer in Lubbock, TX.) I don't mind having a mechanic fix it if need be, though.
I do love this car, and i'd prefer not to bail on it, especially with only 86k miles on the clock.
Thanks in advance for your help, everyone. You'd be lifesavers if you'll help me figure this out.
http://www.youtube.com/watch?v=lUzupnAkiIc
2001 BMW 740il - 86k miles
Old 11-20-2010, 01:23 PM   #2
7seriesmax
7seriesmax's Avatar
Rate My Car: 249 / 337
Your Ride: 1989 735 is
http://www.e38.org/e32/M60EngineSpecs.pdf (pages 5&6) it sounds like your motor has a dislike for the new oil. use a stethoscope to find exactly where the noise is , i hope the link helps you pinpoint what it is thats chattering.
Master cylinder making intermitent clunking noise k2bumper E36 8 03-31-2009 04:41 PM
'99 323i making noise markg E36 0 11-08-2007 03:48 AM
2001 BMW 740iL, Shreveport, LA, $21,500 lowriderdog37 Bmw Cars For Sale/Wanted 0 08-02-2007 09:05 AM
