Old 04-27-2010, 04:47 PM   #1
cddurgin
Your Ride: 95 740i
oil leak through filler cap
I bought a 95 740 with 83000 miles on it. the vehicle runs great but i noticed that i am loosing oil from my filler cap. i thought the gasket was bad so i bought another cap. the oil is still leaking can anyone help
Old 01-22-2011, 03:42 AM   #2
RusserEST
Your Ride: 1999 BMW 728 i
U need to check pressure in engine.
Take next steps: 1. remove cap and hold hand so it simulates cap.
2. If u feel that under the hand is pressure then it's bad. If so, then u need to clean all ventilation tubing on engine. Then maybe it helps to create vacuum in engine. It suppose to help. If not, then u need to check cylinder pressure. There is slight chance that piston rings are causing the problem.
Oil Leak Rockitman E36 9 01-09-2008 06:34 AM
I have an Oil Leak gldfshkpr E36 9 11-23-2007 12:00 PM
1999 323I right wheel oil leak M3ltdown E46 11 09-04-2007 10:22 PM
oil leak in 94 730i BMW730i 7 Series (E23, E32, E38, E65, E66) 6 08-21-2007 09:28 PM
Oil cap question? Mercenary(FH) E36 18 12-05-2006 07:14 PM
