Old 12-03-2009, 10:55 PM   #1
usalexus750i
usalexus750i's Avatar
Rate My Car: 243 / 337
Your Ride: 06 750i
Angry Problem with angel eyes on e65, help!!!!!!!!!!!!
I have a problem with my 750i driver side parking (Angel) lights they stop working and i have a message in the idrive that they not working and see your bmw dealer, any one know what i have to check is any ballast there? i am very handy but this is my first bmw, thank you in advance guys
Old 12-03-2009, 11:08 PM   #2
dwrx04
Your Ride: your mama
your bulb is more then likely toast and you have 2 choices:
1. let the dealer rape you.
2. www.bavtoys.com and you can get a set for less then half the price at the dealer and as an added benefit they will be much brighter and whiter and match your xenon to perfection.
good luck
I AM THE VANILLA GORILLA
member of the..."The bears can smell the menstration...................sercret society for really hung men."
I AM HETEROSENSATIONAL!!!!!!!!!1!!!eleven!!!!11
Originally Posted by CMT View Post
*sniff sniff*
DDm smells like a Jim Powell venture to me. No thanks. I'd be afraid of the mucus trail the call would leave all over my phone. Although in all reality you would probably be fine ordering from them, I wouldn't patronize the place if someone knocked on the door and paid me to run their product
Old 12-03-2009, 11:21 PM   #3
usalexus750i
Your Ride: 06 750i
They both out on one side not just one everything else working fine just this two angel eyes
Old 12-04-2009, 10:42 AM   #4
usalexus750i
Your Ride: 06 750i
Oh i got it one builb for two lights, thanx wrx
Old 08-16-2010, 01:56 AM   #5
aazapf
Your Ride: 2007 BMW 750LI
Just Changed angel eyes BMW E66
Ok, I've just done this job for the first time. Front right light rings were out. computer error message alerted me to it. This is a pain in the A! First you need to buy new bulbs. Buy online and get the LED aftermarket ones. They're cheaper and brighter and use less wattage. I'm in Melbourne AUS and bought them on ebay USA. they were $55USD for two. BMW Australia wanted $73AUD for 1! this is such a pain in the ass job that you should do both lamps while you have the front bumper off. There is one bulb for each headlamp. Each bulb drives the two rings in each headlamps.
Yes, the bumper needs to come off. Remove, the left and right lower plastic grills. (black lower plastic grills) These lever out. No screws. You'll see some bolts holding the bumper in place. Remove the front number plate and chrome grill moldings. Centre one first, then left and right. Disconnect the 4 front parking sensor plugs. You'll see more screws holding the bumper on. There are another two screws on each side near the wheel arches.Unscrew the bolts holding the headlamp washer cover. Unscrew the headlamp washer units. (no need to disconnect). Undo all bumper screws.
Now this is important, the bumper is held on each side by two plastic lips. The bumper needs to he lifted slightly up and forward over these plastic lips.
Bumper should be off. There are 4 bolts holding each headlamp in place. You'll need to get an extension wrench to reach the two near the air intake box. The headlamps lift out forward. You'll need to disconnect the indicator plug for the headlamp. No need to disconnect the big one for the xenon's. The bulbs for the angel eyes are inserted upside down from beneath the head lamp. There's a cover. Remove this then turn the lamp anti clockwise to release. Replace an install in reverse order. I hope this helps as I struggled to find much on the internet on this.
Old 11-19-2010, 08:55 AM   #6
Plyvince
Your Ride: 2002 745i
PArking lights
Where are the parking light bulbs and how do you change them?
I took apart my headlight unit from my e65 and could not find a blown light bulb. The outer zenon headlight (HID) worked and the inner full beam (flasher) H7 bulb worked fine. My problem is the parking light i.e. the circular lights known as angle eyes are not working (which I think is a W5W or a WY5W bulb). The error message on the screen says the left parking lights have failed.
This surely is such a simple solution, any clues?
need advice to get eurolights nd angel eyes blikmmer Lighting 8 01-17-2008 07:13 PM
looking at some angel eyes.... TheUniballer E36 12 06-03-2007 10:24 PM
Those of you with Angel Eyes jrhaile E36 11 04-27-2005 09:58 AM
