Old 03-10-2008, 09:08 PM   #1
sandersnsandy
sandersnsandy's Avatar
Your Ride: 1997 740i
Angry 97 740i engine trouble
Sorry about the repeat but I wasnt able to edit my post---Have same trouble as last post wanted to add that the smoke is billowing from the exhaust not the engine compartment.I am also running a a synthetic oil (could the smell of burning plastic/rubber) be the synthetic oil burning? Also is it possable it could be a head gasket blown thats causing a vacuum in the crankcase? Ive never ran across this type of problem before on any car. Again any help would be appreciated. There was no warning prior to the problem. The engine wasnt overheated,plenty of oil in the crankcase. Dipstick shows only oil,no froth or contaminates.After replacing o2 sensors I took for test drive. The smoke cleared after about a mile,seemed to be running ok.Upon parking It started to blow smoke again. Anyone have a clue on this? Thanks again.
Old 03-10-2008, 10:11 PM   #2
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Your PVC valve which is located on the back of the intake has gone bad alowing that oil vapor to be sucked into the intake and blew out your exhaust.
If your get a shop to replace it thats a really good time to also get your valley pan and water pump changed, since the intake is already off and thats 1/2 the job.
97 740i engine trouble sandersnsandy 7 Series (E23, E32, E38, E65, E66) 8 07-17-2011 03:21 PM
325is Turbo Project, Engine upgrades? BmwCrazy325 E36 9 06-15-2011 01:15 PM
OK - getting codes, CHECK ENGINE light works, but it's not on! volvodefector79 E36 1 11-13-2007 05:46 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Red Check Engine Light browneyedgirl E12, E28, E34, E39, E60 16 03-17-2007 02:50 PM
