Old 03-09-2008, 07:27 PM   #1
sandersnsandy
sandersnsandy's Avatar
Your Ride: 1997 740i
Angry 97 740i engine trouble
Im new to this site so I hope im in the right place to ask---My problem started with a whiring noise sounding something like a tension pully bearing.Put diagnostic and got back codes P1186,P1187,PO300,PO301,PO302,PO305 an PO306 I Then replaced o2 sensors (pre cat) and cleared codes.No new codes have come back. Whiring noise still there and smoking like a freight train.Smoke smells like burning plastic/rubber.I removed oil filler cap only to find its pulling a very strong vacume.With cap off whiring noise stops but smokes just as bad.It only has 94,000 on the clock and I havent had any trouble before now.Dont know where to start. Any help would be very much appreciated,
Old 03-09-2008, 08:14 PM   #2
Rate My Car: 84 / 337
I think one of the accessories may be stuck, and the smoke may from the belt (which will soon break)
Old 03-10-2008, 08:26 PM   #3
sandersnsandy
I wish it was that easy. It Has a serpintine belt and seems to be running smothly along the pulleys.
thanks anyway
Old 03-10-2008, 11:23 PM   #4
Numark318i
Numark318i's Avatar
Title: has an empty wallet
Rate My Car: 119 / 337
Your Ride: ^^
hmm. how about the waterpump? Tat might be the whinning noise?
Old 03-11-2008, 08:26 PM   #5
Antiburn
Antiburn's Avatar
Rate My Car: 191 / 337
Its your pcv valve which is causing that train whistle noise, also the reason your blowing smoke, all that oil vapor is getting burnt. Dealership will change you 6+ hrs labor to remove intake and repalce pcv valve. If you want to do it yourself a 97 v8 has drive by cable, so theres no unpluging the throttel, theres alot of cables and hoses that you have to remove.
Parts might run you about 100$. While your intake is off its a good time to replace your valley pan and water pump, since they both tend to leak and fail down the road.
Also with all those codes im sure they are all missfire faults or fuel trim faults which is unmetered air leaks. Once the pcv is replaced clear them and they shouldnt come back unless something else is also wrong. With all the oil your blowing I know its cloging up your catalitic converters causing premature failure, and they go for $1700 per cat.
Old 03-11-2008, 11:02 PM   #6
sandersnsandy
Just replaced water pump last summer and it seems OK thanks for the imput Will intertain any idea.
Old 03-11-2008, 11:12 PM   #7
sandersnsandy
codes were for the 02 sensors so that part is ok. And I think your on the right track with the pcv valve. Icouldnt think of anything that would put that much vacume in the crankcase. I will leave a note after I replace the pcv valve. Thanks for the imput!!
Old 06-11-2011, 11:03 AM   #8
brett murphy
Your Ride: 2000 bmw e46
the noise you hear isnt a pulley the crankcase vent valve has failed.the excessive crankcase pressure is pulling oil into the intake and being burnt . this valve is also refered to as the intake backing plate. it has a rubber diaphram. this also causes lean fuel trim faults which led you to replace the o2 sensors by mistake the faults will come back.it is difficult to replace the backing plate without removing the intake but it can be done. i would suggest a intake reseal though and remove the intake to save you alot of trouble and while you have the intake off i would replace the valley pan underneath it which is known to fail and cause a coolant leak. if you plan to keep this car just get all the issues behind you at once and enjoy it
Old 07-17-2011, 03:21 PM   #9
Big Evil
Big Evil's Avatar
antiburn and brett, right on the money.
325is Turbo Project, Engine upgrades? BmwCrazy325 E36 9 06-15-2011 01:15 PM
Dressing My Engine GreenTourer Detailing and Cleaning 11 10-01-2007 10:28 PM
Engine Differences htp.bmw E21, E30 4 09-19-2007 10:34 AM
Red Check Engine Light browneyedgirl E12, E28, E34, E39, E60 16 03-17-2007 02:50 PM
Trouble starting car after sitting cold for 3 days..help!? delmarco E36 2 05-28-2005 09:26 AM
