Old 05-04-2007, 12:11 AM   #1
Ntensity
Your Ride: 1993 BMW 740IL
93' 740il Blinker Problem
Hey guys,
I'm a new member here and i have a quick problem. On my 1993 740IL the left and right blinkers work fine when the low-beams are off, But when i turn the low-beams on, the left blinkers are just sorta stuck on. Not blinking or anything, just a solid light. When i try to actually turn the left blinker on through the switch it doesn't do anything at all. And when i try to turn the right one on with the switch it blinks once if that, then stops.
Has anyone had this problem before on an e32? Could anyone help me fix it?
Old 05-04-2007, 12:45 AM   #2
stevo
Your Ride: 1997 318se Touring
sounds like you got a short or a bad earth, might be best to have an auto electrician take a look, could be a fault in your switch assembly at the steering column,or a problem with the wiring at the fuse box, without the right equipment it could take you a long time to find the cause.
Old 05-04-2007, 08:49 AM   #3
Rate My Car: 137 / 337
It almost sounds like someone installed incorrect bulbs in turn signals. Most BMWs use a single filament bulb for turn and running lights. Whereas most domestic cars use a double filament bulb, if someone put a double fliament bulb in place of single the results would be similar to what you explained - a short.
Old 05-04-2007, 10:23 AM   #4
TerryY
TerryY's Avatar
Rate My Car: 5 / 337
Has it been in a body shop lately?
The headlights and turn signal don't connect electrically and the only common mechanical place is the turn signal / high beam / flash to pass switch.
It would almost seem miswired or there are broken wires touching somewhere.
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
Old 05-04-2007, 04:38 PM   #5
Ntensity
Hmm, well i did have the rear drivers side tail light and the front left parking light on it replaced recently, but no turn signal lights. Could this have caused the problem?
A Known Instrument Cluster Problem KickingKing E36 6 11-16-2011 08:50 PM
e36 convert problem Butcher E36 3 09-07-2007 05:24 PM
528I gear problem, Please help me guys, plz plz djfactor E12, E28, E34, E39, E60 3 10-22-2006 05:56 PM
