| 7 Series (E23, E32, E38, E65, E66) General discussion and technical help for all year 7 series cars. |
04-26-2007, 05:54 PM
#1
Your Ride: 1988 735I
My Bimmer Lives
Hey peeps my bimmer runs now but I still have a prob my head light I dont know if I got a bad switch or not they come on when you move the high beam on sometimes so waht could it be well thats it. However there another complication I might have to sell it cause my pour butt probably cant keep it going, so I dont know well, Later
04-26-2007, 07:33 PM
#2
Could you elaborate? I don't really see what you are saying...
04-27-2007, 12:05 PM
#3
like ill move the switch up the light will work for a sec then they go out but sometime if i switch the high beams on and off quickly they low beams will come back on
04-27-2007, 05:29 PM
#4
Look up LKM repair and Mustard relay repair
A soldering iron and a roll of flux core solder fixes most of the light problems on the early E32
$5 worth of capacitors and the same soldering iron fix most instrument cluster problems too.
http://bmwe32.masscom.net/
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
04-28-2007, 10:19 AM
#5
Cool
Yeah Ive already resolderd the mustard relay any others that could cause probs that I should redo like I also have a prob with the hazard light going off on there own I thought I fixed it but it didnt happen that way.
Oh yeah Ill put up a pic of my bimmer soon too it no anything great but its a bimmer none the less and run great now i got that new crank sensor and the fuel gauge works now to Thanks TerryY for the Info man!!!!!
04-28-2007, 11:13 AM
#6
I live to answer technical questions on older big Bimmers. About 4 forums worth
Sticky hazard light switch is most likely cause of random actuation. It is in the finest possible location to collect spilled drinks if I recollect correctly. Sticks partway down.
If that switch is ok, I would suspect the CCM crash control module next.
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
04-29-2007, 08:42 PM
#7
those modules are they the little orange things on the top end of the fender
04-29-2007, 10:24 PM
#8
Orange module are usually related to the air bags.
The crash control module is located under the rear seat but separate from the power distribution panel.
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
04-29-2007, 10:33 PM
#9
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
04-30-2007, 03:01 AM
#10
Your Ride: 1988 735i
what is the year of your car?
It could be the control module under the hood that is the problem with your head lights?
05-01-2007, 09:48 AM
#11
Now I Just Need A Printer Ahahahaaaa......
05-01-2007, 04:28 PM
#12
well how can u tell if its the CCM for the hazzards and the LKM for the head lights. Cause the CCM I pop the top off I grounded myself first but it got this orange stuff all over it but it look ok so i think its the switch that needs to be cleaned up. Now the LKM how do u check it and how do u take it out.
05-01-2007, 05:24 PM
#13
Are fuses F2 F3 F6 and F7 good?
Terry
Aloha Oregon
'95 840
'98 SVT Cobra
05-01-2007, 06:58 PM
#14
i think i found the prob its one of the wire to the bulb connector it seem to have a break in it so im gonna cut and strip it and reconnect it
05-01-2007, 07:36 PM
#15
NVM I guess it the LKM cause all the fuses are good but that one light wont come on I havent had any trouble with the hazards so i guess thats it.
