-   7 Series (E23, E32, E38, E65, E66) (http://www.unitedbimmer.com/forums/7-series-e23-e32-e38-e65-e66/)
-   -   Gas Gauge (http://www.unitedbimmer.com/forums/7-series-e23-e32-e38-e65-e66/10936-gas-gauge.html)
NewBIMMERfan85 04-18-2007 08:14 PM
Gas Gauge
Hey why does my gas gauge go all the way to the bottom right like way way past full and it like less then a quarter of a tank?
RSF5 04-18-2007 09:23 PM
What?? :confused
TerryY 04-19-2007 09:34 AM
Have you put gas in it since you got it?
Bubba 04-19-2007 11:31 AM
Gas Gauge
Quite often the sign of a failing sending unit.
NewBIMMERfan85 04-19-2007 01:08 PM
and where would that sending unit be and would i be able to drive it with it being bad for the mean time i gtg a new crank sensor
TerryY 04-19-2007 01:46 PM
Sending unit is in the gas tank and if you set the trip odometer when you fill it up you should be ok for a while.
It may fix itself with a full tank of new gas dissolving the old varnish coating in the tank.
