Old 12-01-2005, 02:32 PM   #11
nick_318is
nick_318is's Avatar
Rate My Car: 10 / 337
I made one for the pad changes, its pretty easy. I think i listed a size of a wrench wrong in one of my pics but otherwise its allright, thanks for reminding me I will go in and fix the offending mistake. Check the DIY section. I have not bled the brakes but that should be pretty easy you will either need a buddy to help out and pump the breaks for you or else something to create pressure in the brake lines. If you want some more info let me know and I can do a quick little write up.
*edit* Just updated my previous post under a new post with corrections.
