Old 11-24-2005, 09:55 PM   #5
Spieluhr
Title: ///M Driven
if your amp is in the trunk, what is the problem of grounding it right to the battery? or where the battery ground connection is? And always make sure you polish, grind, etc. the surface you are grounding to so you get a clean connection.
what kind of connectors are you using? copper, gold? gold is the best i believe.
