In the winter times when the temperature hits in the 30's sometimes your DDE will take a good while to get to the good temperature to get on. A fix for that is to hard wire the ballast in...
The ballast is located between the high beams and the low beams, it's a small black box...
GENTLY take the ballast out
Then find the two pin connectors...
Cut the cables ONE AT A TIME!!!! then hard wire them, and you'r done
