Old 10-24-2005, 09:10 PM   #14
///M Power
Rate My Car: 25 / 337
Your Ride: 95 m3 turbo
1fast325i
You're goign to get a lot of understeer assumign you have put in some quality sway bars and a non-hinged front strut bar. What helps the most on your FR car is actually lowering the center of gravity by putting in lowering springs and stiffer shocks, thus reducing your suspensions travela nd your cars ability to maintain itself as being flat. Since you have alreayd done the front I would highly recommend that when you do your shocks/struts/springs or even coilovers, that you also put in a rear sway bar. While your at it, might aswell add the rear shock tower bar bcause it is such a bitch to install the rear shocks you're not going to want to have to go do it again later on.
