Old 10-12-2005, 10:07 PM   #5
Torque
Torque's Avatar
Title: Lawl.
Your Ride: '00 Impreza
Not trying to be rude or anything, but did you read that page ?
Originally Posted by the page
Reset Instructions:
(For cars with the 15 pin diagnostic connector)
With the ignition switch at (position two) and the engine not running, grounding pin seven (7) of the diagnostic connector for approximately three (3) seconds will reset the oil service lights. Grounding pin seven (7) for approximately twelve (12) seconds will do an inspection service reset.
Connect the clip end of the jumper tool to a good ground in the area of the diagnostic connector. Connect the pin end of the jumper tool to pin seven (7) of the diagnostic connector. Enter the car and turn the ignition switch to position two (2). This way you can watch the lights reset.
Turn off the ignition switch when you see the lights reset after the appropriate time. This time as mentioned above depends on whether you are doing an oil or inspection service reset.
Remove the jumper and replace the diagnostic connector cap.
(For cars with the 20 pin data link connector)
On the newer cars you also have to place the ignition switch in position two. You provide a short and then remove it after a specified time. The reset occurs on removal. On the older cars the reset occurred after the specified time. That's the difference between the older diagnostic connector and the newer data link connector. I purchased a Peake reset tool to find out what these times were. They say to provide the short for 7 flashes for an oil service reset and 23 flashes for an inspection reset. The 7 flashes for the oil service reset equates to ~ 3.25 seconds. The 23 flashes for the inspection reset equates to ~ 11 seconds.
Turn the ignition switch to position two (2). Connect the clip end of the jumper tool to a good ground in the area of the data link connector. Connect the pin end of the jumper tool to pin seven (7) of the data link connector and remove it after the appropriate time, depending on which reset you are doing. Replace the data link connector cap and turn off the ignition switch. Check to see if the reset worked by starting the car and seeing if the lights go out. If they do, good job!
