Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > 5-Series
5-Series General discussion and technical help for 5-series BMWs.
Old 10-10-2012, 06:37 PM   #1
yellowrose13
Your Ride: 2006 530i
Unhappy '06 530i: needs Radiator and Oil Pan?!?!
Have 2006 530i with 60K miles. Recently had it in for its 60K mile check at Classic BMW in Dallas. Said it needed new oil gasket. Had it replaced. Within days of that work it began to lose coolant. Topped it off but continued to lose it.
Today, took it back to Classic. Was told that the following needs replacing:
Radiator
Oil Pan
All hoses
Ok...I've bought and driven BMWs for 28 years. Why would a BMW need a new radiator and oil pan at 60K miles?? That's not what I expect from a BMW. In 2011 had to replace a warped transmission pan...found out it's plastic and made by GM! WTH?!?
Any advice is appreciated. I'm not settling for this.
Old 10-10-2012, 11:16 PM   #2
DEATH2000
DEATH2000's Avatar
Rate My Car: 111 / 340
Is "Classic BMW" an actual BMW Dealership? I would have taken it somewhere else. Is their any visible coolant? How much are you having to ad and how often?
Im quite surprised the transmission pan would be plastic. Mine is metal. The transmission, if automatic, is actually made by GM in France. The transmission will also have a GM ID number. My E36 transmission is a GM 4L30E transmission also found in the Isuzu Rodeo.
VIEW MY E36 BLOG HERE
