Go Back   United Bimmer Community - BMW Forum > UnitedBimmer- Model Categories > 5-Series
5-Series General discussion and technical help for 5-series BMWs.
Old 06-28-2009, 02:22 PM   #1
jeff8888
Your Ride: 1997 540i
Unhappy 1997 540i AC spitting water
does anyone know how to correct the problem of water spitting out of the back seat AC ducts?......help
Old 06-28-2009, 02:31 PM   #2
Big Evil
Big Evil's Avatar
Has it rained recently? you either have some kind of exterior leak or the more common problem of you heater core is leaking. What else is the car doing? it should be losing coolant and running hot/hotter.
Old 06-28-2009, 09:18 PM   #3
jeff8888
thanks BIG EVIL.....yes it has rained and its been very humid....i have been running the ac alot.....no increase in engine temp .....is there a water drain off for the ac....
Old 06-29-2009, 09:28 PM   #4
Big Evil
Big Evil's Avatar
High humidity causes lots of water to collect and run down the evap, there are 1-2 drains inside the evap case and they do occasionally clog up. You'll have to open the case and shoot a little compressed air through them after some clean up. Replace the micro filter while you're down there and your system should work great. Good Luck
Detailing techniques and products... ivopivo Detailing and Cleaning 2 09-15-2009 02:51 PM
1997 BMW 540i E39 Part Out! ruskiepatzan Bmw Cars For Sale/Wanted 1 01-22-2007 06:53 PM
Coolant bleed problem - 1997 540i zole2112 E12, E28, E34, E39, E60 7 10-23-2006 07:55 AM
Water vs. Coke EnvyM3 United Off Topic  **FOR MEMBERS ONLY** 14 03-25-2006 01:07 AM
Need help (regarding AC) - ASAP! daki77 E36 6 01-14-2006 07:30 AM
