Thread: e30 m3 specs
Old 09-16-2005, 06:14 PM   #2
donald1476
Title: President
Rate My Car: 109 / 340
price $34 000
engine Water Cooled, Inline-4
valvetrain DOHC, 4 Valves per Cyl
displacement 2302 cc / 140.5 cu in
bore 93.4 mm / 3.68 in
stroke 84.0 mm / 3.31 in
compression 10.5:1
power 143.2 kw / 192.0 bhp @ 6750 rpm
hp per litre 83.41 bhp per litre
bhp/weight 147.69 bhp per tonne
torque 230.5 nm / 170.0 ft lbs @ 4750 rpm
drive wheels Front Engine / RWD
body / frame Unit Steel
front brakes Vented Discs w/Vacuum Assist & ABS
f brake size 279 mm / 11.0 in
r brake size 282 mm / 11.1 in
front wheels F 38.1 x 17.8 cm / 15.0 x 7.0 in
rear wheels R 38.1 x 17.8 cm / 15.0 x 7.0 in
front tire size 205/55VR-16
rear tire size 205/55VR-16
steering Rack & Pinion w/Power Assist
f suspension MacPherson Struts w/Coils Springs, Anti-Roll Bar
r suspension Semi-Traling Arm w/Coils Springs, Anti-Roll Bar
weight 1300 kg / 2866 lbs
wheelbase 2565 mm / 101.0 in
front track 1412 mm / 55.6 in
rear track 1425 mm / 56.1 in
length 4346 mm / 171.1 in
width 1679 mm / 66.1 in
height 1369 mm / 53.9 in
transmission 5-Speed Manual
gear ratios 3.83:1, 2.20:1, 1.40:1, 1.00:1, 0.81:1
final drive 4.10:1
top speed 228.5 kph / 142.0 mph
0 - 60 mph 7.0 seconds
0 - 100 mph 19.8 seconds
0 - 1/4 mile 15.4 seconds
epa city/hwy 17 / 29 mpg
