Control arm to final drive carrier (inner): 57 ft-lb
Control arm to rear trailing arm (outer): 81 ft-lb
This applies to both upper and lower arms. Did you use new nuts? They're self locking and designed for one time use. If you reused the old ones, try applying a threadlocker before putting them back on.
