yeah there are a few hoses back there, check your hose to the heater core.. actually try turning on your heater full blast and see if it is hot air, if it isnt either it is that hose or you have air in your system, most likely one, or maybe even both
btw after you replace that hose if you do, make sure you bleed your radiator
