Old 08-14-2005, 08:35 AM   #9
EuroStyle
Your Ride: 92 325i
Originally Posted by billycuth
not hitting anything haile. its a metal on metal rattle.
I forgot about the doughnut. Yes, there was one metal doughnut I did put back in but it was from the old setup (the new one didn't come with it). Should I buy a replacement?
You are supposed to replace both gasket rings when you install an exhaust. They are a one time use product. Turner Motorsport sells an entire exhaust installation kit for the e36, but it is 100.00. At least you can use it as a reference...e36 kit is on this page
It may not fix your problem, but it is a good place to start. Also while you're under the car, you could check to make sure your cat converter hangers and exhaust hangers are in good shape, and secure.
-Matt
