Thread: New Exhaust DIY
Old 08-13-2005, 12:04 AM   #2
billycuth
billycuth's Avatar
Your Ride: 2004 Acura TL
Next, install the new exhaust. I chose to cut the box out around the exhaust so that I could slide it under the car without scratching it. If you leave the rear brackets installed, you won't need any tools yet. The reinstall went so fast, I didn't have time for new pics...
Slide the 2 pipes into the receiving end of the catalytic converters first. One pipe has an extension that allows you to slip the new exhaust pipe over it to hold it in place (before re-securing with new bolts.
Now slip the 2 muffler ties in with the existing rear brackets. Then tighten them. Now, finish by securing the 4 bolts at the other end...
You're done! Here is some comparison pics before the install, and some after install pics... I need new hardware for my setup, but it will have to wait till tomorrow because it is midnight now!
now that you see how easy it is, save yourself the money and BUY ONE!!! I recommend understeer.com. Chris is a great guy!
