Old 07-14-2005, 04:18 PM   #2
Rooz
Rate My Car: 5 / 340
Your Ride: 2003 M5
Bavauto I think sells the cupholders...
The glovebox issue is a comon problem on our cars... I am sure you can find a DIY fix for it somewhere here... if not use this:
Fix A Sagging Glovebox Door
Tired of your glovebox door sagging down and leaving a gap at the top? Of course you are! Here's a quick and simple way to fix it.
You will need the following:
- Hand drill
- A small drill bit
- Tape measure
- Small screws
- Screwdriver
Open the glovebox. Along the top edge of the glovebox measure and mark spots 2 1/2" to the left and right of the latch. Using a drill bit that is slightly smaller than the treads of your screws, drill holes when you made the marks. Tighten a screw in both holes. The screws will clamp the glovebox tighter against the vent panel behind it.
And I am pretty sure you can find the touch-up-paints at your local BMW dealership, if not let me know what color your car is and I'll tell you what color from another brand would match it best....
VIEW MOD LIST & PICS
Originally Posted by Gregg
