AHH. I don't get it. The amp is rated 400W RMS @ 4ohms yet my 250W MAX channel from the 500/5 is much clearer and louder than the new amp.
Could anyone think of what it might be? Apparently something isn't setup right. ie: wiring faulty or incorrect in some manor, amp settings are wrong. i don't know and i can't figure it out. =0
here are the specs on what i have. maybe someone can figure it out.
Subs -
Nominal Diameter: 12 inches (300 mm)
Continuous Power Handling: 300 Watts
Voice Coil: 2.25" diameter, 4-layer, Kapton former
Available Configurations: Dual 2 ohm, Dual 4 ohm or Dual 6 ohm
Amp -
» mono subwoofer car amplifier
» 400 watts x 1 at 4 ohms (600 watts RMS x 1 at 2 ohms)
» Class D design
» Bass Engine® features:
• low-pass digital filter, 30-200 Hz, with a selectable 12 or 24 dB/octave slope
• selectable subsonic filter (off, 15Hz, or 30 Hz with 24 dB/octave slope)
• Bass EQ (0-16 dB at 45 Hz)
» CEA-2006 Compliant
i'll reply when i get home with the ohm and other specs of my particular subs. please comment with ideas though so i can begin troubleshooting.
