Old 06-19-2005, 07:56 PM   #1
komodo
komodo's Avatar
Title: Administrator
Rate My Car: 68 / 340
Your Ride: 1995 M3
Just Dropped My Car Off
I just dropped my car off. Bittersweet moment.
I won't be seeing it again until later this week.
In addition to the crazy amount of other mods, I'm now installing UUC Transmission Mount Reinforcements. There are 3-4 other things I decided to go ahead and do also like replacing the rubber boot connecting the dinan cai to the engine, and an oil change. When my brakes are changed, he's also going to paint the calipers red which should look cool. Also I'm finally going to get my ACS Petals installed. The cams are coming in tuesday probably, so I'll drop them of when they come in. For the GPS module of the AVIC-N2 headunit, I'm probably going to get a E46 style sharkfin and mod that to be the gps antenna.
Another mod I'm thinking about doing is replacing the computer and sunglass holder of the center console with a fitted 7" lcd touch screen connected to a trunk mounted computer. I'd use this to tap into the obd2 system of the car via usb and output realtime stats of the car on the screen.
Another mod I'm seriously thinking of that would be insanely cool is.... have any of you seen the Transporter? You know that digital code ignition system he has? I'm thinking about mounting a keypad and burning an eprom to trigger a relay when the right code is entered that will in turn start the car. I would disassemble my key and mount the chip inside the dash near the ignition so I wouldn't even need that. All I would need is to get into the car, enter the code, and the car would start. No key. I'm waiting for him to get back to me with prices on this. haha, that'd be hot though.
