umm 3 bolts that are easily seen up front and 2 on each side.. might have to remove the plastic cover thingy that's in the center/front of the engine bay... also you need to take out your corners first too.. I just took the grey wire and spliced it into the grey/purple wire going into the corners... this also does a cool effect if you have an alarm with lighting... like on my girls car, when she hits her alarm, the halos flash at the same time as the corners :P
