Old 09-12-2012, 03:26 PM   #5
poolshark0487
Your Ride: 1984 318i
Took off the maf sensor this morning and she wouldn't even start. Since I know its getting plenty of air and a good spark then I knew it had to be in the fuel delivery. Took the injectors out but left them attached to the fuel rail to test the spray. There was the problem, there was very little spray coming out of only one of the injectors. Found an ingenious way to clean them online too, all i need is some fuel injector cleaner, a water bottle, and a 9 volt battery. I'll let you know if it works.
