My car does not have a fan clutch as it is fitted only with and electrical fan which sits behind the radiator, No fan on the engine at all. The electrical fan won't kick in at all. So no fan for any cooling..???
Any Ideas..?
As stated previously the thermostat, water pump and radiator are brand new, with new silicon radiator hoses. Only one fan though and that is electrical. It doesn't work at all.
Thank you in advance.
By the way the diagram you posted shows a fan that is not fitted to my car although there is a one inch threaded shaft protruding from the harmonic balancer where a mechanical fan could be fitted.
BruceM
