Old 04-10-2012, 07:34 AM   #17
antymated
Your Ride: 93 bmw 325i e36
i will double check any vacuam leaks. and i was looking at the Idle Control Valve do you think its possible because of that?
Also how do you check for ignition timing and for a jumped timing chain...
also how to check idle control valve if still working...
"note": i took the idle control valve out and using possitive and negative and all it did was vibrates...and even on the engine...it still just vibrates... does it mean it still good?
would you hear a click sound...because i believe there is a click sound before every backfires... (if you listen on the video you probably can hear it before you see the flame).
Thanks for your help Death2000....
