Well if you have needed cleaned your MAF or throttle body I would do those. Power steering flush if that's never been done. Its a little bit more difficult but trannsmission fluid and differential fluid should be changed. Make sure you inspect all your bushing and steering components for wear. Rear Shock Moints (RSMs) are prone to eventual failure. If you hear a clunk in the rear that's usually a good sign their bad.
