Old 09-26-2011, 12:44 PM   #2
Big Evil
Big Evil's Avatar
Low coolant issue, leak somewhere in the system, air bubble in the system, bad radiator cap, failing water pump or clogged radiator causing an overheat, failing cooling fans causing an overheat (that's the basic stuff). Or more seriously a warped head/failed head gasket (which is less likely but there's not enough info to go off of in your question).
