Old 06-02-2011, 03:18 AM   #11
jungleman
jungleman's Avatar
Your Ride: 1998 e36 2.3l
My 323i has done 175k but i found after replacing the seals in the Vanos the car seems to be far more responsive you can definately feel that the engine has quite a lot more power than before, but i would also recomend checking the sensor ie- crank and cam, i found after replacing the Vanos seals and doing a diagnostic scan found the crank sensor was playing up thus adding to the running problems
hope this helps.
