Old 03-23-2011, 08:41 AM   #1
scooter
scooter's Avatar
Title: Administrator
Rate My Car: 295 / 340
Your Ride: 99m3
Fight fires with your BMW R1200GS, sorta
Filed under: Etc., BMW, Motorcycle
German company Rosenbauer has found a novel use for the two-cylinder boxer engine found in the BMW R1200GS. The company has used the engine to power a water pump for use by fire departments in areas where traditional fire trucks can't reach.
The pump produces 68 horsepower, which is enough to move about 530 gallons of water a minute, which Rosenbauer says the pump can keep up for 300 hours straight, assuming you have an ample supply of gas and water.
The rig is technically portable, but with pumping equipment and a fairly big motorcycle engine attached, it isn't what you'd call lithe. Ready to run, Rosenbauer says the rig weighs 367 pounds.
[Source: Rosenbauer via Motorbiker | Image: Rosenbauer]Fight fires with your BMW R1200GS, sorta originally appeared on Autoblog on Wed, 23 Mar 2011 07:57:00 EST. Please see our terms for use of feeds.
Read | Permalink | Email this | Comments
More...
