Old 12-04-2010, 09:13 PM   #9
lasmariaspr
Your Ride: 1995 325is
Well today I tested crank sensor and it was good. Tested for continuity of wires 85 ground of both fuel pump and dme relays to ecu pin connector and were good. Still have to test ignition wire which I read feeds the ecu dme. But also, car starts with ground wire connected to dme socket pin 85.
