Old 11-01-2010, 08:10 PM   #4
krislou80
Your Ride: 2009 BMW 323i
If you're already having a hard time managing your vehicle when you make turns, then its likely that one of your control arms has been compromised. Inspect your control arms for signs of wear and tear, and if one of them is in bad shape, then promptly replace it with a new control arm . if you are referring to on the actual steering wheel, then some grinding noise is normal. it's possible the electrical contacts for airbag/cruise/radio controls, whatever you have on the steering wheel are making some grinding noise.
