Originally Posted by amath80
I had a problem with my power steering system. the fluid and lines are fine but the power steering pump are out. would i change my steering pump or not? help guys....
you probably want to change your
power steering pump.When the fluid is low and you add some ... it still needs more after you run it for awhile. The reason for that is that the pump pumps the fluid through the lines and gets out the air in them. Keep filling and checking after you start the car and turn the wheel from side to side all the way.
