Old 10-06-2010, 09:24 AM   #3
dtom4
Your Ride: 1996 328i
[QUOTE=chapps;174085]Dave,
Their is a screw (A-KEY 3mm I think) about 1/2 way down the shaft section of the T bar. Move the bar into first then feel around at the front. Remove the screw then pull the T bar up it will come off.
Thanks Marc. I finally found it after posting. Exactly where you said it is. Found it by feeling the handle and felt the opening at the front of the handle. Now on to figuring out the no start issue
Regards
Dave
