Hi, you will need the battery charger as mentioned in the FAQ. The uploading procedure needs more voltage than the battery alone can supply. I tried an automatic battery charger and it did not work and not having a manual battery charger, I used another running car as done in a jump start situation. It uploaded in no time and I've not had any problems since the upload..
