Thread: Frozen 318I
Old 09-16-2010, 07:12 PM   #2
Dink318i
Your Ride: 1994 E36 318I
If you have 5k and another 3k for installation of a turbo on your car i feel this thread is a waste of your time or you can go buy the turbo and pay me 1500 and i will install for you.
this is for the person who just wants more horse power and is a turbo fan as i am. I purchased the ebay turbo kit and no it dose not come with everything you need in fact some of the stuff i am throwing out like the cheap BOV, it didn't even fit the BOV pipe and really that was the only thing i am not using. it comes with a 57 trim turbo ( you can rebuild it with garret parts as it is a knock off of a garrett, they say max output is 450 hp if you do not have a built motor you are not squeezing that much out of a M42, the Intercooler piping is good, the Intercooler is probably on the cheap side i will upgrade the whole system in time but for now i will get experience building and tuning, and who cares if you are the DIY type you can get a whole motor shipped to your house for $650 most of your tires cost more than that.
In my case I had a cracked head most places said that they did not repair cracked aluminum but the places that did charges $300, I got a use head in good condition but the cams were spun so i used the cams and cam housing from my old head, it looked like someone did not do oil changes at all. so with the engine opening up and the new head on the way i said why not go for a cheap turbo kit! the ebay turbo kit came with 57 trim turbo, oil feed and drain kit, vacuum tee's a lines, turbo timer, manual boost controller, fuel pressure regulator, turbo manifold, down pipe, boost gauge, wastegate, intercooler and more than enough piping and couplings i used almost half of it. to complete the kit you will need fuel pump, Comectic head gasket, ARP 2000 head studs, I got 440cc injectors, 255 walbro fuel pump, and some type of engine management. I got the W.A.R. Chip, it is like a stand alone and it give you total control over spark, fuel, and boost, and can not wait to get on the dyno with it, and you will need a maf. I got the wrong one for a 95 motor i am researching to see if i can splice some lines to make it work. you will need to get some extra nipples for the oil lines and for you guys that will have a top mount on an e36 good luck i was quoted $1500 for a custom job and there really isn't enough room for a good top mount in a e36, the strut tower is too close. but the kit came with catch can, and that is the other thing i am throwing to the side till i get a scavenger pump, the turbo is too close to the oil pan i foresee draining issues without it.
