Old 08-24-2010, 05:00 PM   #9
scooter
scooter's Avatar
Title: Administrator
Rate My Car: 294 / 337
Your Ride: 99m3
Originally Posted by Clarksonvalley View Post
Scotter.
Throw out the 222# on cylinder #8 and the remainder of the figures are within 5% of each other - acceptable values. The 222# figure is probably a result of some carbon buildup due to the fouled plug. Thinking back about 6-8 months, I would occasionally have misses on startup for about 15 seconds, then it would clear up. Now, the plug is just not firing at all. I have verified continuity of the wiring to the #8 ignition coil, so I suspect the DME. Do you have any ideas what might be causing the non-firing on #8 cylinder?
Tom
my guess would be the ecu as well as long as everything else has been ruled out.
are you getting any fault codes? misfire on #8 etc?
sometimes a vacuum leak can cause some carnage.
