Old 08-16-2010, 12:35 PM   #1
jaylee0128
Your Ride: 2001 bmw 3.25i
2001 bmw 3.25i please help with problem
Takes longer to start, and idles BAD. When accelerating it feels like I have about half the power, and rpms jump and stop without being smooth.
I ran a scan and the camshaft and crankshaft position sensors showed up.
What makes it complicated is when it first started doing this the abs light came on as well. So i dont know if the problems are connected or not.
I changed both sensors, but im still having the problem.
The camshaft sensor code isnt showing up anymore, but the crankshaft is still showing. I erased the codes after changing and it popped back it up.
I didnt know if someone knew of something that could trigger the abs with the crankshaft code, or is it just a weird coincidence.
Hopefully someone has had a similar problem, or a good idea of how to fix it without giving the dealer thousands of dollars.
