All the warning lights work? Functioning normally warning you of problems or just all lit up?
The clunk is most likely the center support bearing on the driveshaft is blown out (fairly common). You'll have to partially drop the exhaust and driveshaft cover to check it.
Not sure about your warning beep, neither of my e30's ever beeped at me.
