Thread: Wont start
Old 07-10-2010, 08:24 AM   #32
macky55e34lover
macky55e34lover's Avatar
Your Ride: BMW '94 E-34 525i
we,, if you had the battery recharged and it started, you have to check with the electrician and see if the alternator is working properly, maybe its not charging anymore, check all of the sensors also specifically the crank sensor, if this is busted, there are times that it will run then suddenly stop without warning
