Old 05-20-2010, 12:19 PM   #15
willie0915
willie0915's Avatar
Rate My Car: 135 / 337
Your Ride: M3 1995
Hello, may sound crazy, but if none above have result you can check the flex disc between the front section of the driveshaftand the output flange of the transmission should be checked for cracks, tears, missing pieces, or distortion. Check for worn bolt hole bores in the flange. It happends to me once and after I replace the flex, Problem solve.
