I ended up buying the B-90 Sir Tool...worth every last penny. Pulled the old bearing right out and pressed the new one in...re-installing the hub with the tool was simple as well. However, now I need to get the axle back inn. Is there only one way to line up the teeth or should it just slide back into the hub??
