Originally Posted by 3050rpm
Could be. Also check fuses, maybe a relay. I'm not sure, but there might be a backup light switch on the case of the transmission, obviously activated when reverse is selected, which could have been affected by the storm.
+1 ^
weather changes with moisture usually cause poor contacts with the bulbs, though it may be coincidence an it's a fuse or the backup switch
