Old 02-10-2010, 08:26 PM   #2
siven
Your Ride: 2004 BMW 325CI CONVERTIBLE
Originally Posted by Vik View Post
Now it is nice to be back home from Iraq, it was a long and HOT trip. Quite a few days with over 120 F but all came back to -7 F. Now the most disappointing thing however was that my heated seats don't work. The light comes on for a split of a second and turns right off on both sides. Please, if you could help, let me know what's up. There are no fuses in the fuse box responsible for it. I've seen quite a few posts online, but none of them solve this problem. So please let me know if you know the solution. Thaaank you
Are your seat come with Factory Heating Elements or Aftermarket's ones?
I have installed aftermarket kits however there are same problem with you. As I have tried 2 different kits from two different suppliers, they are not carbon firber. I think they are not compatible with console switch. Only one heated seat kit that I have found it will work with console switch is:
http://www.heatedseatkits.com/heated...at2/index.html
If your seat come with heated pads, so I have no idea what problem it is. They should be fault's wires. Please double check with all wires back of switches. They may be disconnected by little rats.
Good luck. If you want to replace them try to purchase from my link.
