You just need to clear fault codes at this point? You can enter fault reading mode by turning the key to the ON position and stepping on the accelerator (to the floor) 5 times in 5 seconds. To clear codes while in self diagnostic mode simply depress the accelerator for 10 consecutive seconds. This should give you a code of 1000 which means that the system is clear.
