The drains for my sunroof are located in the front corners correct? Where do they drain out at exactly?
Also, the inner panel on my sunroof is messed up. When i open the sunroof everything slides back, but when i close it the inner panel doesn't slide forward with the rest like it used to, i have to pull it shut and it only shuts 3/4 of the way, then it stops and i can't pull it ahead anymore. (hope i explained it good enough)
