Old 11-27-2009, 10:14 PM   #8
dunsgamer
Your Ride: 1995 325I conv.
are you ingaging the starter when you are looking for power at the fuel pump? the pump only runs for 5 sec.and then will not start again untill it see's the starter run. you can turn the switch off and on and it will not run the fuel pump. try just bumping the starter each time you check the pump voltage.
